Hello, and thanks for opening this thread. I've read/relied on these forums for quite some time, and finally have something of substance to ask. (I think it'll be quite some time before I'll be able to answer anything of substance).
How I want to make my life difficult:
I have a desktop with Win XP Home and a Laptop with Win XP Professional.
Both XP discs are upgrade versions. The desktop had Win 98 on it, the laptop (a Dell Inspiron) had Win ME. I have the original (i.e. licensed) Win 98 and Dell installation discs, and both licensed upgrade discs.
Is there a way I can upgrade the desktop's XP Home to XP Professional and downgrade the laptop from XP Professional to XP Home? Is there a way to do it without losing all the software/ configurations I have on the two machines? That is, can I do it without subsequently re-downloading/installing a slew of programs and tweaking the systems to how I'm used to? Also, although I plan on backing up as many data files as I can, is there a way to swap operating systems without having to rely on the backups to copy back from? In short, I'd like to avoid simply wiping each drive and starting from scratch.
What? I'm not making my life difficult enough? Ok, well, here we go...
I'm replacing the desktop. It's currently a PIII 550. I'm putting an AMD 3700+ (939) into an Asus A8V-E. Which means when I switch the current drive to the new system, it will be sitting in an entirely new Motherboard/chip configuration. I've heard that XP's authentication and settings don't always take well to such a switch.
Speaking of making switches, this is the last wrinkle (I think). The current drive is a Western Digital EIDE drive. I'm also getting a newer WD SATA drive. At twice the capacity and higher speed, I'd like to make that my primary drive.
So.... so.... so now what?
I am considering putting the new system together, installing Win 98 on the SATA drive (will that even work?) then upgrading/reregistering Win XP Pro on it. Then installing the EIDE drive as a secondary hard drive and migrating all data from there. BUT, then I lose all system configurations and installed programs, don't I? And I still have no idea if I can downgrade the laptop's operating system. There are a few other buts, so I'm pretty sure this is an option of last resort.
Should I get the upgrade/downgrades done, put the EIDE drive in the new system, deal with XP's change of hardware issues, install the SATA drive and finally mirror the old drive onto the new?
Egad, I'm making things difficult. Can anyone help?
Rhythm
PS
I hope this is the correct forum/structure for asking this question. If not, please accept my apology.
PPS
If it makes any difference (or if you want to point out a glaring mistake) this is the full description of the new system:
Case: Antec TX640B, 400W power supply
Chip: AMD ATHLON 64 3700+ (SAN DIEGO)
Board: Asus A8V-E Delux
RAM: Kingston 1GB DDR400 (512MB X 2);
Drive: Western Digital 160GB 1600JD SATA-150
Video: ATI Radeon X800XL PCI Express
Again, thanks!
