I took care of business last night. I replaced the KT4 Ultra with the EP-8K9A2+. I made sure that I had read the manual and I did not replace any extra peripherals (etc modem). I fired up the system and it booted as a 2100+ but would not go into windows.
I put WinXP disk into dvd drive and started the repair. By the way, you first pick install and then pick repair. I then let WinXP install disk do its work and applied the service pack1, too. Now, I was in windows.
Of course most of my hardware drivers were not up to date (video card, sound, modem). In fact, I could not get the modem to work until after I installed the SP1 and Via drivers and the onboard sound would not work until I install drivers. After install latest via 4-in-1, Nvidia video card, and onboard sound drivers everything is working great.
I got online, without any trouble (had to add init code to turn off speaker). I ran 3dMark2001 SE at the default 2100+ (scored a litter higher than KT4 at same setting). I ran some Unreal 2. I ran some audio, too. Everything was working great!
I then added extra peripheral (printer, Scanner, Digital Camera). Then are all working great!
Overclocking Time: I had two goals I wanted to achieve from swapping these mobos 1st, I wanted to break 2.0GHz on the processor (with out ridiculous over-volting). 2nd, I wanted to break 12,000 on the 3dMark2001 SE. Both goals were accomplished. Right now I am running at 12.5 x 166MHz = 2075MHz @ 1.75v ~42-44degrees. I ran 3dMark2001 Se and Prime 95. Rig is running stable.
Thanks for all of your suggestions.
