Swapping out primary hard drive for SSD: Fastest method to transfer data and OS?
ChrisAttebery
118
I'm considering putting an SSD in my machine and I'm wondering what the fastest way to move the OS and data off the old drive is. Is there any way to copy the entire drive and OS without having to reinstall everything?
I'm currently running Vista 64 bit.
Thanks in advance,
Chris
blackangst1
22,902
2,359
Im assuming you mean for your C drive? Just use Windows backup to make an image, put image on seperate drive, install new drive, restore from image.
CptCrunch
1,877
Whenever i install a new operating system on my computer, I setup all of my applications, new drivers, updates, etc, and then make an imagine with Acronis. When I want to "format", I just reload the imagine, apply updates or newly found programs, create a new imagine. Rinse and repeat. I've only installed Windows XXXXX version once, then used images.
