SW1 on sa6r
ALstonLoong
1,627
hi guys ,
May i know how should i set the SW1 setting to overclock my celeron2 633 to 950 ? This celeron should work on that frequency fine. I tried it on be6-2, is fine and stable..but not on SA6R.ANyway have any idea on this thanks
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
I have mine configure this way.. 1,2,4,6,7,8 off 3and 5 on.. running a PIII coppermine 700E cc0 @1050 using Softmenu III for all settings.. you should be able to run any processor using this setting.
mastertech01
Nov 13, 1999
11,875
282
It may be, but you should check ram timings as well..like backing off to 7/9 and making sure no conflicts with PCI cards at high fsb.
ALstonLoong
1,627
well my ratio set to 3-3-1 ...should have a problem with pci i think.From the begininning my ram is timing is default ..i didnt change anything on that. I dont know why abit wanna use this ratio ....like be6-2 is using different kind of setting. We can change the frequency of agp and pci ...
mastertech01
Nov 13, 1999
11,875
282
Unfortunately they dont allow using a PCI setting individually like BE6II.. :( Thats a drag when using between 100 and 133 FSB especially Thats a limitation of I815 though, not Abit
