SVideo (first timer) Help!
Beal
hey all,
First time poster here.
I have a question regarding Svideo and using my computer monitor aswell as a TV (So I can watch shows etc.) from my comp on the tv.
I've got the Gefore 6600 GT and I have the Svideo hooked into a "Connectall200" monster cable splitter thing. Then I have the regular cable cord from the connectall 200 to the TV.
Nothing is showing up on the TV and I have absolutely no idea what I am doing.
Will this even work?
Dont want to sound patronising if you have, but have you restarted? Once you have, go into your display properties, then click the settings tab, you should be able to work it out from there.
Thanks for the Reply fifth,
Just to anwser your question yes I had restarted.
There was a problem with my power outlet actually.
Problem is solved now
