Hi ,
I got a letter recently saying someone recieved spam emails from my IP and 1 of my systems may have been infected with spyware .
So i was cleaning out 1 of my systems and monitoring the Internet connection and found this annoying thing which i cant work out .
When i turn everything else of and its just basic windows resources running , my LAN connection shows 10% Utilization at a constant perfect stream along the Networking Graph in Win XP Task Manager .
The only thing that stops this device using the LAN connection it to disable the 1 instance of svchost.exe thats using the most RAM .
Then the LAN connection shows 0% Utilization but it also turns the sound device off ???
Can anyone tell why this is and if its a problem ?
None of my other systems show this , The LAN Connection shows 0% in use when i close all browsers and apps .
