soccerballtux
* Scion tC first gen has approx 60/40 weight distribution FWD
* Koni Yellows on full stiff in front (just dialed that yesterday), bit less than half-stiff in rear
* Eibach Pro-Kit spring set
* tRD rear sway bar (it's pretty thick) on sport setting
* alignment good
I've noticed on heavy braking especially while turning, nose dive and ... unstable handling.
So I set the front suspension to full stiff. Helped a lot with the nose dive. But I miss the cushier ride.
That's not why I'm posting though--
I'm experiencing a bit of, I guess chassis roll. At 70-80mph, I start a turn, car starts the turn, chassis squats a bit with the weight transfer, finally grabs, and then as it grabs the tail swings out a bit. What should I change? Is that a bit of oversteer? I'm leaning towards setting the rear shocks to full stiff as well since this helped so much with the front end's behavior. However, I previously had them at full stiff and dialed them back due to "harshness" on speedbumps. Now, I think I don't care-- I want clean handling.
* alignment good
