Survey on PC Noise
mcvan
164
Hi Everyone!
Silent PC Review is conducting a short survey designed to answer the question "What is a Quiet or Silent PC worth to you?" There's a draw for several PC components to be given away -- performance heatsinks and a high quality, noise-reduced power supply unit.
PC Noise Survey
One entry per person. Results will be posted periodically on our site. Thanks for your participation!
BD231
10,568
138
Good survey, might want to get someone to change these:
1. How much you you plan to spend on your next PC (without monitor)?
*2. How much you you plan to spend on your next component addition or upgrade?
mcvan
164
Originally posted by: bdog231
Good survey, might want to get someone to change these...[/i]
Thanks for pointing that out! Proofing -- the bane of the writing existence!
