Surround Sound Headsets: A question, 5.1
evolvedbullet
543
Razor Headset
According to Razor's site, it says that these headsets (Razer Charcharias) have 5.1 surround sound. I do not notice that it's 5.1, it sounds like headsets that have a higher volume output and a deeper base but has the sound of a 2.1 headset.
1)Is their any drivers out for this headset that might enable the 5.1
2)Is it possible that something is obstructing the 5.1 from getting to my headsets?
and
3)If their are no drivers or anything that could possibly be obstructing the headsets 5.1, is their a chance that I might be plugging my headsets into the wrong port? (and if you know, what port should I plug it into?)
If you want pictures, I can give them to you if youd like. Thanks.
mpilchfamily
3,559
Is what your listening too outputing in 5.1 suround sound?
Keep in mind that the 5.1 souround sound is simulated and the headsets should have came with some drivers to help in that.
