Surge suppressor help
MBony
2,990
I have 16 timeclocks that I need to protect from lightning. Should I get something like a battery back (APC 350VA?) or do I need something more powerful or something different altogether? I don't believe the timeclocks consume very much power.
Update: Each unit costs ~$1300
FoBoT
63,084
15
fobot.com
wrong forum
do they need to be "on" when the power is out?
if yes -> small UPS
if no -> normal surge suppressor, rated for lightning
how much do they cost? (the timeclocks)
a cheap UPS will run you about $35-$50 , so if these "timeclocks" cost ten times that, i would go with a small UPS anyway
Mark R
16
What do you mean by 'protect from lightning'?
Keep running in event of a power failure; prevent from being fried in event of a lightning strike (how close would the strike have to be before you'd accept the equipment getting fried?); both?
MBony
2,990
By protect I mean keep from keep it from getting fried; it doesn't have to be on at all times, it just needs to work at all times there is electricity. But if having a battery backup isn't much for , I would go w/ that option.
