Surge Protectors & UPS?!
mad0maxx
Hey can a surge protector go bad? I read an article a while back that stated everytime a surge protector took a surge the protector would weaken to the point where it would not protect the equipment on the surge protector anymore...
Also would you recommend getting a Surge Protector or a UPS for computer hardware and please recommend item or brand name thanks...
Originally posted by: woowoo
Yes.
MOV's are one shot devices
What is a "MOV's"?
Also if they go bad why would anyone wanna spend more money on a UPS because would they not go bad as well? Or are they different from surge protectors?
Also when I say surge I mean like when a thunderstorm comes by power instantly shuts off or a or at random anytime a sudden drop in power for a split second causing all things power in the house to flicker.
Originally posted by: goku
It's possible. Buy from APC and they've got a warranty on your stuff.
Would that be a surge protector or UPS?
APC sells anything that is power releated. Personally getting a UPS is always a better option because they have power correction to make sure your system isn't undervolted etc.
Yes.
What is a "MOV's"?
Metal Oxide Varistors.
<------ General Hardware is that way.
Yes.
What is a "MOV's"?
Thank you.....
Just be sure you know when that warranty ends. Then you can decide how much your ass is hanging out when it's gone...😛
Also make sure whatever outlet you plug the UPS/Surge protector into is properly grounded. Looking over the warranty info from APC, if you don't have the outlet grounded, they will give you problems while trying to claim. If need be, have an electrician install a new grounded outlet.
You should have grounded outlets anyways as it's for safety.
They may have warranties, but they may give you a hard time when the time comes to hand out money for damaged equipment.
I would say UPS...I got one last year for christmas and its one of the best things I've gotten for my computer! Great for when the power flickers, but not for extended blackouts. I have a APC BR 800 and it works great...can power my rig with 380W PS, 2005FPW, and a PentiumIII rig for about 25 minutes.
Something I've read also is that if there is a light on your power strip and it is flickering or out, replace the strip.
