SuperPI Problem with my x2 3800
goobernoodles
I've got a x2 3800 @ 2.5 that I'm trying to test out, and whenever I start calculations on the 2nd instance of SuperPI, I get an error "NOT CONVERGENT IN SQR05"
Whats this mean?
download prime95 and do a torture test. most likely your cpu isnt stable. what voltage are you at? memory settings?
CPU is at 250HTT x 10, v1.45, 35c idle 49c load.
Memory is at 208Mhz 3-4-4-10 vdimm 2.75 (Its 200mhz 2.5-4-4-8 Stock rated from 2.55-2.95)
NF4 @ v1.55
Prime is OK for 15+ min, need to do more. Memtest is ok after 3 passes.
