- Sep 2, 2000
- 4,567
- 11
- 81
I am not going to go balls out on modding this case being it is rather ugly in terms of constuction. But it will pave the way for future mods I will do. Here is what I had in mind of doing.
Painting.
I think Honda Red from the TRX250R four wheeler of mine would look
for the exterior. While the guts/drives go either high gloss black or ultra flat black (I think flat would looke better than gloss). But I am open to other color schemes if any of you care to comment.
Case cutting.
This case is very cool in stock form. But I have a plethora of 92mm Adda fans sitting around brand new doing nothing. Where would good placement of these fans be? I was thinking two on top (blowing out), two on the left case cover over the CPU/Video card. (blowing in).
Also modding the 80mm front hole from the front that sucks air at the bottom in to a 92mm hole. The top rear already has accomodations for a 92mm fan.
But then I have a problem of more air blowing out than in because of the PSU. Unless I reroute the blow to the top of the PSU since there is a 92mm fan hole right above the mount. But will that hurt the cooling of the PSU? I am getting a new Vantec Stealth 520W sometime soon. But I would hate for a new PSU to have a short life.
Or am I just over paranoid of negative pressure?... I think not though because negative pressure attracts the killer of anything in this world. That being dust.
Hard Drive mounting.
I am sure that drives vibrate causing noise. I was thinking that I could get some heavy ¼" steel plates and have my friend who works at a machine shop make me some heavier mounting/securing for the drives. Would that cut down on noise? Or should I use the same ol' flimsy stuff that comes with all computers? Placement for what I had in mind would be at the bottom front where the 92mm fan mod would blow onto them.
With a thin rubber pad, just bolting it to the bottom. That would keep it secure and vibration free wouldn't it?
Window.
Not sure if I want to pay top dollar for a kit. However buying Plexiglass locally is rather cheap as I can cut it myself. But where would I find the molds? They must ship USPS though, check signature
But I am not sure if I want to do the extra work of a window being all I look at for my PC is the monitor/keyboard, not the computer.
LED's.
I am tired of the color scheme of green/yellow. I want to replace them with white/blue/purple (or red) ones. I have no idea what size the stock ones are though. Can somebody enlighten me to the size? Also where to buy them (see above for window mold).
Monitor.
Not sure if I will paint it black or red. I am thinking black with the buttons as red... or visa versa. Ahh yes, that green/yellow LED must go.
Keyboard/mouse.
I have a Microsoft Intellimouse Optical. The red LED seems okay. But I would like to change it to blue. Or does the optics require red?
As for the keyboard. I am thinking buying a corded version of Logitech's flagship instead of cordless in the color black. I will leave the keys black, but I want to paint the rest of it to match the box.
Printer.
I am open to ideas. But is it worth the time to paint it?
Speakers.
I think they will become red, with the speaker covers black... and that stupid green LED will go also.
Any ideas on what else I should do? Also feel free to comment if I have am missing something. (Besides the cold cathode... I dont want to get into that stuff just yet on this practice case.)
Painting.
Case cutting.
Window.
LED's.
Monitor.
Keyboard/mouse.
Printer.
Speakers.
