Superfetch max memory?
Xsorovan
320
So I'm going to be installing Vista here at work on my personal machine, (no one else gets it, I'm not an IT Manager with a glutton for punishment) and I was curious if anyone had any solid numbers on how much memory Superfetch will use. Will it use as much of the jump-drive as you allow it? (IE: if I plug in a 16gb jump drive can it use all of it?) Or is the Superfetch capped at a certain level?
Thanks...
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Your talking about ReadyBoost, and as stated the limit is 4gb and yes you can set the lower limit on the device itself (its in the drive properties).
