Superbike 2001 loading problems - please help
willawake
18
somebody please make my weekend please. i just bought ea sports superbike 2001 and took it happily home but when i load it it says :
D3D Error Message - Invalid Video Mode
i mean cmon wtf?
I have creative annihilator ddr with detonators 6.50 in win98 and directx 8.
MTDEW
4,284
37
I'm afraid I'm not gonna be much help, but I can tell you it should definately run on that card.
Ive got a Creative Annihilator GeForce2 Ultra / DX8.0 / 6.31 det And it runs fine.
I can run with 6.50 too, but I loose my OC tab & Ive been to lazy to lookup how to re-enable
it for the 6.50s since I saw no difference between the 2 drivers.
Maybe try reinstalling DirectX 8, if it asks to reboot when its done, then it
may cure your problem, however if Directx 8 install just says its done & displays an "OK"
box without the reboot option then DX8 was ok.
Are your video settings for your card "tweaked"?, Like having some default options
turned off that would normally be on, or visa versa?
Youve gotta get that game running, its awesome!
If you do get it running, try the "on bike rider view", now thats one
heck of a joyride.
If you need to compare system settings for reference, just email me, I'd be glad to help if I can.
MadAd
429
im not sure if your card option supports it, but i got exactly that when I upgraded to my V5 and had geometry assist enabled. turned it off and went racing again :)
Justin
Look at the properties of the shortcut, if there's a "-d3d" or similair, delete it. On a relatively off topic note, does anyone know where to play Superbike 2001 online? My brother absolutely LOVES this game, heh, you should hear him go off when he wrecks :D.
