This is an updated version of a similar setup I posted about earlier. It's purpose is noise reduction. I have removed both fans from the Truepower 330, and am using a Compusa 120mm fan in the center of the oak padded box. There is a PCToys controller in the front.
The computer case is completely sealed except for a filter in the former PSU opening. The airflow goes through the filter, over the board and CPU, through a hole under the hard drive, and into the lower box. The last four pictures show an updated acoustic filter which allowed better airflow with reduced noise.
This thing works. The system is running quietly and very cool with two fans....the 120mm fan in the cooler box, and a small undervolted cpu fan. I'm not finished with the computer part yet. I am attempting to run the whole system off the 120mm fan, with the cpu fan only turning on at high loads. We'll see...
Super System Cooler
Super System Cooler
