Super Pi benchmark - Post your 1M and 8M times!
cowdog
283
The variabilty of results is interesting. For example, as listed above there are 3 2500+ cpus o/c'd to different levels
@ 2200 MHz - 1M = 44 s
@ 2300 MHz - 1M = 46 s
@ 2406 MHz - 1M = 48 s
That's not the trend I would have predicted. What performance factors generally influence results? Higher FSB compensates for some overall MHz? Memory timings? Just curious.
Markfw
May 16, 2002
27,328
16,158
Athlon64 3000+ @ 2.18
1M=41 sec
2M=1 minute 34 seconds.
Elcs
6,278
Mobile Barton @ 200x12
1M = 44s
8M = 8m 20s
Mobile Barton @ 200x11.5
1M = 47s
8M = 8m 40s
Pifast = 53.13s
Mobile Barton @ 220x10
1M = 43s
8M = 8m 20s
Pifast = 51.67s
Same old Barton @ 215x11
1M = 43s
8M = 8m 4s
DAPUNISHER
32,121
32,697
A64@2.3ghz 1:1 vDIMM 2.9v 3-5-5-11 timings :eek: :p
1M=40s
2m=1m 31s
8m=7m 14s
pic
PiFast= 55.66s
NokiaDude
3,966
AMD Barton 2500+
512mb Kingston HyperX DDR333 RAM CAS 2-2-2-6-1T
1M= 58secs
8M= 10m 40secs
pillage2001
14,038
1M is 56 seconds. Does it matter since I'm on a Kt266A board or this test is base solely on clock speed?
imported_Phil
9,837
1M = 52s on an AMD 3000+ @ stock speed, memory at SPD speeds on a Leadtek K7NCR18DLM (nForce 2).
8M = 9m 49s. Not too shabby for stock speeds with generic PC2700 RAM :)
cowdog
283
A64 3200+ @ 2300MHz (10 x 230, memory at 5:6, 6-2-2-2, LDT = 2.5)
Super Pi 1M = 38 seconds
A64 3200+ @ 2200MHz (memory at 220 1:1, 6-2-2-2, LDT = 2.5)
Super Pi 8M = 7 min 16 sec
AWhackWhiteBoy
1,807
"NW @4.8GHz (300x16 5:4 2-2-2-5) = 5min 34sec
Prescott @4.5GHz (281.5x16 5:4 2-2-2-5) = 5min 33sec"
hahaha,you can see the P4 doesn't scale well at all. 300mhz = 1 second?
cowdog
283
Well, I just managed my fastest Super Pi times so far! I was especially happy to break 7 minutes for 8M.
A64 3200 @ 2298MHz (9 x 255.4), approx 2300MHz is max for this cpu/mobo combo, however I go at it, without finding a way to get more volts. Next I will try to go down to an 8x multiplier and see how high I can the HTT.
Super Pi times:
1M - 37sec
8M - 6min 59sec
MichaelZ
871
1M - 41 seconds.
2M, 8M... decided against running and played games instead :p
To those curious which factors affect the benchmark times, I'm guessing ram timings has more of an effect over raw mhz. Friend with a 2.8C @ 3.5 running Corsair @ 2,2,2,5 got 40 seconds on his rig. :beer:
AWhackWhiteBoy
1,807
Originally posted by: i82lazyboy
1M - 41 seconds.
mhz isn't everything, core has a lot to do with it. the P4 has been more than generious with scaling, can't expect a whole lot more out of it.
