Super Duper Simple Circuit Help?
Nov 17, 2019
13,458
7,907
I should be able to do this in my sleep, but it isn't clicking for me. I want LEDs on each of the two power legs coming into my house. Why? Doesn't really matter, just a gizmo thing.
It's wired as in the sketch, but it doesn't work right. What should happen is that if Leg 1 is lost, D1 should go dark and D2 should remain lit. What happens is that D1 stays lit, but at about half brightness. Same way the other way around, D2 is dim is Leg 2 is lost.
These are cheap Chineseum LEDs and are packaged for 120VAC with no indication of Anode or Cathode. Not sure if I should try to flip them around (change polarity which shouldn't matter on AC), or if I need some other isolation diode.
sdifox
101,216
18,226
Well you have breakers on both phases so just wire one light bulb to each opposing breakers. Wiring straight to main in is a nono
sdifox
101,216
18,226
Then what is the issue, just wire up a couple of medium base sockets in parallel to the existing Romex wires then put led light bulbs in them.
Paperdoc
2,523
388
I doubt you can get what you want without a much more sophisticated circuit. Basically the devices you have contain a resistor and a small LED which ideally lights up fully at 5 VDC, but will still light up weakly down to about 1.5 to 2 VDC. But of course it only lights and conducts current when the voltage is "forward" for that diode, and is completely dark with near-zero current flow when the voltage is inverted, as any AC supply will do. The LED's each must be rated to withstand the Peak Inverse Voltage in the circuit, which will be about 175 V at the peak of a sine wave. So each LED actually pulses on and off 60 times per second,so fast you don't see the pulsing light. The resistor in series with the LED is sized so that, at the maximum current flowing through the LED / resistor serial pair at the moment of 175 V forward voltage, the peak current flow though the LED (whatever that is, known to the manufacturer) is such that the Voltage drop across the LED is 5 V, and across the resistor is about 170 V. At lower forward voltages in the sine wave the forward current through the pair is lower and produces less light, but still not NO light until the forward voltage across the LED drops down to less than 2 V. At that point the current is much lower, so the drop across the resistor is also lower. but still, if the ratio of voltages is about 5/175, then at 1.5 V across the LED, the total forward voltage drop across the pair is about 50 V, with VERY little current flow. So, any small induced currents flowing in that circuit of "dead" supply leg through the light unit to Neutral may be sufficient to produce a small amount of visible light. In a household power supply system there are enough connected devices and parallel wires carrying current to cause very small induced currents in adjacent wires, so achieving real zero voltage on both supply line legs when one is still operating fully is almost impossible.
Since you have these units installed downstream of the isolation switch / incoming breaker, I expect that if you shut that off so BOTH legs are "dead" then both LED's will go dark. However, if you wanted to ensure that one LED will go dark when the other leg is fully operating, you;d need a very different circuit for each LED that can really shut off ALL possible current flow at even very small forward voltages that originate in induced small current flows. I don't know a simple way to do that. You best path forward may be simply to accept that "Off" is signalled by LOW brightness, not NO brightness.
Nov 17, 2019
13,458
7,907
Correct.
That's why I was wondering about an extra diode to block flow, but I don't know enough about it to know what to try.
I really don't want to think about ICs and drivers since I have six of these in place to monitor three sources.
