- May 21, 2001
- 13
- 0
- 0
hi, i have an array of objects in one class, called algorithm. The array of objects is stored in the class, vertex. I have another class called a priority queue which takes the array of objects values from class vertex and puts them into a binary heap. The problem is with my organization. I CANT ACCESS ANYTHING!!! im really lost on this so this is wats up. I dont think i can get the values from vertex into priority queue becuase if i create an object, it wont have the array of objects. So i need to go through the algorithm class, BUT if i go and create an object to the algorithm class, it'll clear away all the values. so the question is. Is it possible for me to create an object to a class without goin initializing the constructor and wiping out all the old values? And if possible, can you tell me a better way to rearrange my classes and information and values? THANKS
