Sunoco vs Other
MBrown
5,726
35
Someone from work was saying he only puts Sunoco gas in his car because he says its better than all the rest. Is there really a difference or is gas just gas at any gas station.
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
The gasoline is the same.
The additive package may differ, but in most cases the gasoline is the same.
Sunoco may actually be an exception to this rule however, as some Sunoco stations still offer Ultra 94 or Ultra 93, which may be a higher octane than other stations in the area offer. Some stations may even offer Sunoco 260GT, which is a 100 octane street-legal fuel favored by weekend racers.
ZV
geokilla
2,012
My family uses Sunoco only if possible because they heard the same thing.
However, I'm trying to give them an alternative, which is Shell. Shell's V-Power is 99% Formula 1 fuel because that's what F1 regulations state.
roid450
858
maybe try taking the cat back out and running VP u4.2 oxygenated fuel with lead :Q
lol
LuckyTaxi
6,044
23
i dont care what anyone says, sunoco is much better on my car. I get more out of it than let's say LukOil or Exxon.
I've tried Shell a couple of times and I dont have any complaints. When I used to drive to our old job location I would avg roughly 240 miles on 3/4 tank on sunoco gas.
With exxon or lukoil, i got roughly 180 or so.
jhu
11,918
9
that last part doesn't make much sense. unless you have some way to substantiate that (readouts from the ecu, etc.). i've also found driving styles play a large role in mileage/tank. perhaps you were driving less aggressively on the sunoco tank vs. the exxon/lukoil tank.
zerocool84
36,041
472
There is no way in hell the type of gas would result in a 60mile difference.
bruceb
8,874
111
If I have the choice I do run Sunoco myself. Second choice would be Gulf. You need to try the same octane of various brands and see how your car likes each. Some will idle smoother or start up a bit better or just may feel more perky when you hit the gas. But Sunoco is tops. That is what they use in Nascar at the tracks. (race gas spec)
overst33r
5,761
12
I hope you realize Shell isn't the only supplier of fuel for F1 (Mobil, elf, etc)
jhu
11,918
9
indeed. i find driving style makes a substantial impact on gas mileage.
alkemyst
83,769
19
statement #1 and #2 are not equal.
In most cases is right...but if you are only considering the quikee mart type then you will find a ton of range.
geokilla
2,012
Up here in Toronto, the only "race-spec" fuel are Shell, which is known for F1 and Sunoco, which is known for NASCAR. The other major gas brands are Esso and Petro Canada.
Isn't Texaco a good brand as well?
@Lucky. That is definitely not possible. 60 miles = 100km. That's a HUGE difference. You were probably driving more aggressively or did more stop and go in city traffic.
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
Gasoline != additives. The statements are perfectly compatible.
With very few exceptions, stations buy gasoline from whatever refinery has the closest distribution center. Some Sunoco stations will have gas from a Sunoco refinery, some will have gasoline from an Exxon refinery, some from a Shell refinery, all depending on where they are physically located.
ZV
JDub02
6,209
Of course Sunoco is the best. NASCAR uses it, so it gives you +15 horsepower.
Vette73
21,503
9
You, and your car, will not know the diff between any gas.
The only real difference is the stations and their pumps. If the tanks leak, bad filters, etc...
I had a friend that was a brand queen. Would only use 1 brand. So I told him when I used his car I filled it with another brand. Well he swore up and down his car was weaker, milage had dropped, etc... after he said that I gave him the reciept that came from the same station he always used. Then he tried to come up with another reason...
Gas is gas.
lurk3r
981
Gas is gas.
Wrong, just wrong, I mistakenly put the 87 in my tank last week, and there was a noticable loss in power, nearly a full second 0-60. The altima is rated for 87 octane, but mine performs noticalbly better with 89, 89-93 dosen't make any difference.
Just because YOU don't notice a differnce dosen't mean that noone will.
alkemyst
83,769
19
ZV
regardless you are going off the poor man's belief that gas = gas. In reality the transport, storage and delivery have A TON to do with what you end up with.
There is a major reason people don't line up down the street at the 'quikee marts' despite their gas being much cheaper usually.
Vette73
21,503
9
Gas is gas.
That is not rated by the quality of gas but the octane rating. Yes a lot of cars will perform better with higher octane gas. Of course a lot of cars do better with higher octane gas as the owner is to stupid to take care of their car properly and as such will not perform on the gas it was made for.
Also you do know that there is no 89 octane. 89 at stations is a mix of 87 and the high octane (92 or 93).
Quality =/= Octane rating.
I only use Chevron with Techron.. but thats because i have a gas card with them.. and thats what I use to fill up my car.
LuckyTaxi
6,044
23
Nope -
stop and go traffic on the highway. I don't go above 75 most of the time. I tried this for a few good months, alternating between sunoco and lukoil/exxon and found a big difference. My car only takes premium so I always used the highest (sunoco using the second to highest).
I can see if 1 or two days I went above 80 most of the time but i barely do it just because the traffic is horrible where I live.
zerocool84
36,041
472
I use Chevron cus it's the closest gas to me. Laziness FTW :thumbsup:
lurk3r
981
Gas is gas.
Also you do know that there is no 89 octane. 89 at stations is a mix of 89 and the high octane (92 or 93).
Wow, now you've called me too stupid to take care of my car properly just because what I observe proves your opinions wrong, good argument!
For the record, all scheduled maintence has been done, and I've observed the same results on this car, (and most of my other cars) since it was brand new.
and no octane rating is not quality, but it does lead directly to more efficient combustion, the engine can advance the ignition farther, increasing the compression ratio at which combustion occurs, which produces more power and wastes less of the gas making the engine more efficient.
If you want to keep your head in the sand, enjoy yourself.
Vette73
21,503
9
Gas is gas.
Just because you follow what is in the book does not mean it is working correct.
I was ASE certified and ran my own shop. So your single observation is not proof of anything, other then you do not know what you are talking about.
