I have already tested the Sunbeam unit with all 5 case fans and it works no problem. Now my CPU fan is the Tornando that uses a 4pin power plug with a small single yellow RPM 3 pin. I bought a 4-3 pin adapter so I can run the tornando directly into the 3pin power on the back of the Rheobus. Well I tested the Tornando with 2 different 4-3 pin adapters and I pluged into proven bay channels so I know the Rheobus is working. It just does not work if I plug the fan into the adapter then into the Rheobus, the fan works if I plug it into the Power Supply, what gives? I do know the fan has another black/yellow cable in the 4 pin plug that is not accessed due to the 4-3adapter is only red/black. How do you guys get your Tornando fans to work on these Rheobuses? I am stumped and it sucks but I have to leave my problem cause I have to leave to work. I hope some of you have incountered this and can help. Thanks.
