Sun Microsystems Monitor
Dec 31, 2005
110
I bought a sun microsystems 21" CRT monitor. My friend told me it had DVI... but I'm tellin you all it WON'T fit from all of the DVI card pictures I have seen. From left to right its got 1 big pin, the set of small pins and then two more big pins. I looked on the sun website and found:
Video input Connectors: HD-15, BNC
Cables included: HD15M/HD15m 1.8 meters and HD15/BNC 2 meters
What the heck kind of cable is that? Its NOT DVI, right?
Dec 31, 2005
110
Can someone tell me that they don't know? Or is it that this is a really stupid question and no one wants to bother?
Dec 31, 2005
110
Its got a regular monitor connection on it too. I'm using it with my geforce4. I just wanted to know what that other thing was.
That site has a dvi plug... My monitor doesn't have dvi at all... or those coax type cables.
nitromullet
9,031
36
Those coax type plugs are the BNC connectors. As long as you have a regular VGA, you're fine though.
Dec 31, 2005
110
I know I'm fine. I just want to know what the heck the other plug is... If I take a picture of it can someone host it for me so I can post it?
