Sun Block Lotion Question
AntMan530
I just bought a generic brand Sun block. It states all the ingredients that banana boat, coppertone etc.. has, but it doesnt have that seal recommeded by the skin cancer foundation. What does that really mean in quality?
I'm thinking its cool to use it, but maybe you guys can persuade me its not. I am white, so its really important. all opinions are appreciated
Sunblock blocks both UV-A and UV-B and is mostly comprised of organic molecules that absorbs all of the UV. Just check the SPF since it really doesn't matter what the ingredients are. If it has high SPF (at has to be lab tested), then it gives you that protection guaranteed. Now just look for ones which is waterproof and long lasting
An alternative would be to smear zinc oxide all over your body. You will look like an animated snowman, but you won't get burned. 😉
that would go perfect with my shoulder length hair too 🙂
Hmm....
There can be differences between brands and generics in terms of working during / after swimming and also how long you must put the screen on before swimming. Coppertone Sport is my preference (goes on easy and shortest application before going in the water), although my first long surf session on a run is always met with Hawaiian Tropic 70 as I've yet to find another brand at this SPF.
Brand matters in terms of waterproof and durability claims. Cheap sunblock like No-Ad proclaims things like all day protection and waterproof/sweatproof, but I've never had good experiences. I stick with Bullfrog.
As for ingredients, the best sunblocks contain titanium dioxide, but some others that don't have it are still not bad.
one thing most people dont know is that the SPF factor only gives you the protection from UV-B. Currently, no standards exist for UV-A, the type that can cause cancer. Get one that says broad spectrum. Ombrelle is a good brand
