Sukhoi's SETI@home Help Thread
Confused
14,166
Seeing as Sukhoi's thread seems to have disappeared, i decided to repost it :)
SETI@home Installation FAQ
Poof's SETI Driver Help Page
Get all your help here! First off, thanks to anyone who is switching to SETI. To get an account, just fire up the client, and you can select a new account from there. Then make sure you join TA by going here.
Clients:
GUI - Screensaver client, generally slow, only use if absolutely necessary.
CLI - Best client to use, especially with the other addon programs. Works in 9x/ME/NT/2K. Win95 machines need the Winsock 2 update.
Mac - If you have a Mac.
Mac OS X - GUI client if you run OS X, regular Mac client may be faster.
Other OSes - For those strange people with Linux boxen.
Russ's SETI Driver Setup Disks - Should make it real easy to install SETI Driver.
9x/Me/NT/2K SETI Service Installs - SETI service installs, including Win9x/Me.
LRP Bootable Linux Client - Crack rack time.
Bootable SETI - Another bootable Linux SETI client.
CLI NT/2K Service Install - Another service install.
IsOs's 9x/Me SETI Driver Service Install - Make sure you replace the user_info.sah with yours. Also check the priority setting in SETI Driver.cfg.
IsOs's 2K SETI Driver Service Install - Make sure you replace the user_info.sah with yours. Also check the priority setting in SETI Driver.cfg.
My Service Installs:
CLI and SETI Log NT/2K Service Install - Original files from office boy, I changed them around a bunch.
CPU1, CPU2, CPU3, CPU4 - Here are my SMP capable CLI and SETILog NT/2K service installs. For a two CPU machine, DL CPU1 and CPU2. For a four CPU machine, DL CPU1, CPU2, CPU3, and CPU4. CPU1 is not the same as the single CPU install version, so don't try to substitute that one.
Addons:
SETI Driver - Most popular WU caching addon. Good for a single computer, and also gets the CLI out of the taskbar and into the systray.
SETIQ - Best for LANs and for use as a proxy. Good stats.
SETIGate - Another multiuser proxy, SETIQ is probably better.
SETIStash - Caches WUs.
SETIHide - Hides the client and caches WUs.
SETI Door - Linux WU cacher.
SETILog - Provides logging for the CLI, also can use the /h switch to run the CLI hidden.
SETILog for Linux - Not much to say here.
SETIWatch - Lets you monitor clients, works over a network too.
SETISpy - Everything you ever wanted to know about your WU, and a lot more.
SETI Monitor - Um, monitors SETI.
SETI@Home-Log - Another logger.
SetiTEAM - Save team stats to a spreadsheet.
SETI Launcher - Works with SETI Driver and has it upload and download WUs when a dial-up connection is present.
Stats:
Live Team Stats - Realtime updated CGI page.
Individual - Get your individual stats here.
Orange Kid's - Lot o' stats.
Soni's - More stats.
Smokeball's - Smokeball's daily stats.
Nexus9's - Lot more stats.
Top 25 Teams - Seti@Netherlands stats and graphs for the top 25 teams.
Graphs - Some older SETI graphs, I need to get the new ones done.
Proxies:
Orange Kid's - More WU caching and stats.
Miscellaneous:
SETIQ Guide - More SETIQ help.
SETI Bandwidth - Shows just how much bandwidth we're using.
SETI Timer - Estimation of WU times based on processor.
Seti FAQ - Tons of answers to your questions.
Also, here is a link to the Welcome to the Distributed Computing Forum thread, check it out for a little more info on Seti @ home, and also on other Distributed Computing projects TeAm AnandTech do :)
ConfusedBW
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Bump for hugeamounts of INFO :) Thanks for my Info hit for today :) Now I need another Stat Infusion so I can sleep easy :)
Robor
Um, how 'bout a lock at the top for the upcoming race against DSLR? I really don't want to see another HW France deal...
peang
269
bump :)
i was wondering how come this threat was not put permanent bump so it will stay on the top.
this threat i think is very good for any new user or member so they don't have to search to all the message. this is just my opinion ;)
Sukhoi
15,350
Yeah, maybe tonight or tomorrow I'll change the few links that need to be changed and repost it. :)
DDad
TTT- This is just too handy to have to look for, especially if you are new
NoReMoRsE
2,078
I've said it before and I'll say it again... BUMP!
Check my sig for information on setting up SETI@Home! It's as easy as pie!
