Suitable replacement for an old A8n Sli se
CHayes
9
Thanks for the help.
I have an old A8n Sli se that no longer works. Is there a suitable replacement for this board, or will I need to order the exact same one?
My video card is a 8800 gtx and using DDR 400 ram
Thanks again
tcsenter
18,892
543
Originally posted by: alyarb
socket 939 boards are incredibly expensive and hard to come by. you'll have to use ebay.
I would seriously avoid the A8V-XE. The VIA VT8251 SB had serious issues. It was used by ASUS for a while then ASUS stopped using it in favor of a newly revised VT8237 (which is the SB that was supposed to be replaced by the VT8251).
