It's probably not as noisy as some of your systems, however, the dB output is still significant, and considering I have a plexiglass window installed, it's not helping to contain the noise.
So, here are the specs:
Antec SX1030
Abit KR7A-RAID (for clearance issues, KT266A chipset)
Stock PSU w/temp controlled 80mm
2x 32.5CFM, 2670RPM, 28dB front
2x 32.5CFM, 2670RPM, 28dB back
Athlon XP 1800+
Thermalright AX-7
4100RPM 80x25mm fan on AX-7 mounted with rubber grommets
My CPU temp loads around 15*C higher than system at 50*C
Obviously, the main source of noise of that 4100RPM fan on my AX-7. Is there anything I can replace/do with it do reduce the noise? I haven't kept up with cooling the past year.
I was thinking a HUGE FSCKING heatsink would be nice, like for the P4s. However, there's obviously the issue of clearance.
I'm on a budget (poor college studnet), so cheap solutions please i.e. no watercooling
A maximum output from any source should be no more than 35dB
Solution 1
I will replace my current 32.5CFM case fans with these which are 36CFM
That's a 12% increase in case airflow
The big question, however, is in regards to my CPU fan I currently have a 52CFM fan. I am not certain but I will guess it is at least 40dB
I am thinking of replacing it with the Smart Case Fan or Smart Case Fan II
Solution 2
I have a 120mm Panaflo High output that I could rig to my baybus. I could then run it at 7v and rig it to sit over my AX-7. Somehow I imagine there will be duct tape involved
However, the fan will be sucking air from what appears to be small area. The back case fans and the Panaflo will be fighting for air which would not be good. Still, since I will be rigging, I could rotate the 120mm slightly to pull air from more in the front of the case. Once again, the downside is that the air will not be directed at the AX-7.
Antec SX1030
Athlon XP 1800+
Thermalright AX-7
Solution 1
Solution 2
