Suggestions: thin/light 13" - 14" laptop
White Widow
773
The screen just cracked on my 4-year-old Acer (yeah, I guess so,me Acer's do las a while) and I'm more than ready for something new. This is *not* a gaming system. All I really want is:
- under 1" thick
- USB 3.0
- backlit keyboard (preferably chicklet style)
- solid battery life
I was looking at the Samsung Series 7 ans Series 9 as well as the Acer Aspire S. I really like the matte-finish/higher res on Samsung 7 screen.
Any other suggestions are appreciated, especially if I can save a few hundred $$$.
Thanks,
Aaron
Zap
22,377
7
If budget allows, probably anything marketed as an Ultrabook will fit all your requirements with the exception of backlit keyboard.
For something cheaper... how about a Dell Vostro V131? While not perfect, it meets many of your requirements. It starts around $500 with a dual core Sandy Bridge CPU, weighs 4.1 pounds with the 6 cell battery and is mostly under 1" thick, except the 6-cell battery sticks out the bottom rear (almost like a stand). Battery life is a claimed 9 hours, so it should easily make 6-8 in normal, non-demanding use. Supposedly there is a 4-cell battery available which sits flush with the bottom, thus the notebook would be under 1" thick. Screen is 13.3" matte. A backlit keyboard is available, but usually comes with the more expensive models and not the cheap $500 model.
Anandtech reviewed the Dell Vostro V131
The review wasn't that great, but I like mine just fine. Known problems are that it isn't silent, and the left side hinge can start clicking or get loose.
Pardus
8,197
21
Lenovo is to release two new ultra books, the 13" IdeaPad U310 and the 14" IdeaPad U410 in May. No back-lit keyboard in any Lenovo products.
HP Pavilion dm4 and dm4 Beats Edition are also solid machines.
Laptops I didn't care for:
Lenovo Thinkpad: very poor resolution
Acer Aspire TimelineX: poor build quality
Dell XPS 13: TN panel with poor viewing angles, poor color, poor contrast, and just poor quality all around.
