Suggestions on case lighting
XBoxLPU
4,249
I have the CM-Stacker with Side window panel.....
DFI NF3 UT250 ( rounded cables are UV and so is motherboard ).
What do I order ? A single 12 inch UV and mount it vertically besides my motherboard just behind my ide cables. Or dual 4 inch UVs...
I also would like a blue cold cathode. 4 inch or 12 inch?
albumleaf
238
buy all 12's.. you'll be happier ( igot two 12' blue cold cathodes with dual inverter for $7 at directron)
HardWarrior
4,400
23
I have 2x12in tubes and 2x4in tubes, all UV. The 4-inchers come in handy for those times when you can't find a 12-inch run and\or you have tight areas you want covered.
imported_rod
1,788
Id get 12in. I haven't got them yet, but I'll be putting 2x12in UV neons on the left and right sides of my window, and a 12in blue and 12in green at the top and bottom.
What UV reactive stuff have you guys got in your cases? Im getting some Vantec UV Slot protectors, a couple of UV reactive fans and some UV cable sleeving.
RoD
