It has been a lot of years since I've been up to date on the most current hardware standards and just know enough to be able to put things together (like legos)
I deal with quite a bit of graphical information at once so need large monitors, and would like two 30" monitors but can't justify spending that much. So I'll be most likely buying:
* Hanns-G HZ281HPB 27.5'' 3ms Full HD 1080P HDMI WideScreen LCD Monitor (two). Hey, it's on sale (with good reviews)!
* TRENDnet TEW-623PI IEEE 802.11b/g, IEEE 802.11n (draft) 32-Bit PCI. Nice, it's on sale (with good reviews)!
In terms of the video card, for every day use, I'll be mostly looking at charts all day so almost any video card will do. Will need the video card to be able to drive both monitors. Would like to be able to watch HD movies on the monitors and maybe some HD video editing as well. The following video came to mind, can you guess why?
* HIS H577FK1GD Radeon HD 5770. It's on sale (sort of) and has good reviews!
Will have to look up what "CrossFireX Support Video Card w/ Eyefinity" means. Looking down the road a year or so, there is a possibility of going with two 30" monitors. At which time I will need a card (actually two) that supports Dual-Link DVI to run the resolution at 2560x1600 on each monitor. I'm not familiar with Dual-Link DVI but the HSI the max resolution is 2560x1600. Ideally I'd like the video card I'm purchasing now to have the ability to be reused and I would only then need to buy an additional Dual-Link DVI capable card. Need a bit of help on the video card department. For instance, how do you know by looking at the specs of a video card whether or not it is Dual-Link DVI capable? And if it is, safe to assume the card could do dual monitor on a standard 24" monitor?
I am a big fan of the small form factor Shuttle computers, and am currently looking for one (suggestions?) May have to compromise on the size a bit in order to have the option to just stick in a second video card to drive the larger 30" monitors (if I ever decide to upgrade). Won't be overclocking anything, just want a stable system that is relatively small and quiet without spending more than is necessary.
Open to all suggestions, inputs, advice, etc.
Help me get a system together Anandtech!
/edit: will be adding some additional things as well:
* APC BR1500LCD. Used to own one (and it has good reviews!) :laughing
