Suggestions on building 2 pcs.
KingLou
Hello all. My dad asked me to build him two new PCs to replace some aging dinosaurs for him. One for his home and one for his office. So let's get right to it.
Home PC
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
General computing, internet, TV/video streaming, graphics editing software, some gaming. He would like this PC to have good graphics handling capability (but this is my dad we're talking about, he's not looking for some quad SLI rig). Also, as much processing power and ram as is reasonable. My thoughts on hard drives are 512 gb ssd and a 1-2tb platter drive for storage.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1200-1500
3. What country YOU will be buying YOUR parts from.
US
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No brand preference except I would like to make this an Intel chip build. I tend to lean toward nvidia, but if there is an AMD option that fits the bill that's fine too.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No current parts to be used. However, he is not in need of any peripheral components.
7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds only.
8. What resolution, not monitor size, will you be using?
1920x1280
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Immediately
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows 7 only.
Office PC
Office work. Mostly invoices, and quickbooks. And he works with A LOT of windows open. I mean A LOT. Some other odds and ends and general computing, internet. No gaming, though he would like it to be graphics "capable"....no need to get fancy here. He would like to go with two 1 tb platter drives in a redundant setup for some data safety. Probably will forgo and ssd for simplicity and cost.
$1000 or less.
US
1920x1280
Immediately
Windows 7 only.
You guys have helped me tremendously with my last three system builds. Your judgement and suggestions have always been spot on! Thank you!
KiL
No cursing in the technical forums please.
mfenn
General Hardware Moderator
Will the "office pc" be for a home-office or an office at some company? If the latter, get some major brand with a support contract. If the former...that's not a bad idea either. :twisted: An SSD would be nice for this system too, but may not be practical in a major-brand system.
RAID is not a backup! If this is for a home office, you might want to use CrashPlan to back up to the Home PC.
Not really sure what "some gaming" really means, nor "good graphics handling capability" since what you listed, apart from gaming, could be achieved with the integrated graphics.
Anyways, for the home PC:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($178.73 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($68.98 @ OutletPC)
Memory: Crucial 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Crucial MX100 512GB 2.5" Solid State Drive ($189.99 @ Amazon)
Storage: Hitachi Deskstar 2TB 3.5" 7200RPM Internal Hard Drive ($67.03 @ Amazon)
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card ($145.99 @ SuperBiiz)
Case: Corsair 350D MicroATX Mid Tower Case ($89.99 @ Amazon)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($51.08 @ Newegg)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer ($14.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($88.98 @ OutletPC)
Total: $955.74
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-03-01 01:56 EST-0500
For the office PC, I would remove the vid card and double the RAM. You can even get a cheaper CPU, like an i3. I would also get a 2 or 4TB external drive (or 2) for backups. Also, I would recommend switching to Windows 8.1 rather than 7 (and get a 3rd party start menu program).
Also for the work PC, since he opens a lot of windows, I would look at a larger monitor, like a 30" 2560x1600 or so.
Office PC example:
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor ($104.75 @ OutletPC)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory ($109.98 @ OutletPC)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($99.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($47.89 @ OutletPC)
Total: $676.62
Generated by PCPartPicker 2015-03-01 02:20 EST-0500
This. A redundant HDD will allow the system to keep running. It offers very little protection for data. Overwriting a file, accidentally deleting the wrong file, or some program bug causing data loss/corruption happen at least as often, if not more often, than data loss from disk failure.
Now, as a home office machine, a RAID 1 might be good to have to minimize downtime in the event of an HDD failure, but regular backups are the way to protect data. With decent broadband (>1Mb upload), a cloud backup service that constantly updates files will do the job well, after the initial seeding.
I generally like OlyAR15's builds.
