Originally posted by: JackBurton
Originally posted by: QuixoticOne
I'm switching over from using USB / PCI client NICs to using access point/routers at BOTH ends of the connection, and wired ethernet connections from those to the devices to be connected over the wireless link between the two APs.
You can do this if your AP supports "WDS bridging" or "Client Mode" operation. Not too many APs support it well or at all with stock firmware, but several models can use custom 3rd party firmware (like DD-WRT, OpenWRT, etc.) to allow the function.
In the case of a client mode AP the other (main) AP never really even needs to know the other one is anything but some random wireless client, it can't tell the difference.
I figure the firmware for the APs is probably more highly evolved and reliable than the junk drivers you see for the PCI / PCI-E / USB Client NICs which are just HORRIBLE to use under Vista / LINUX / etc. much of the time.
This way if the wired ethernet drivers work on any given computer, voila, that's all that you need to get a wireless link that is pretty reliable.
You can also use some of those dedicated "wireless game adapters" that you'd use to connect a PS3 or Xbox or whatever console ethernet port into your existing wireless access point, they're just typically "client mode" type of wired ethernet to wireless ethernet converters.
And with the APs you probably have better antenna options and stronger transmitters etc.
Exactly. just get a Linksys WRT54G or GS, install some 3rd party firmware, and set it to
Client Mode. You don't have to worry about blue screens from crappy wireless card drivers, less resources used from your machine to keep that card working, and it's pretty flexible (you can move it to another machine easily). As far as your machine is concerned, your using a nice and simple wired connection. That's what I'm doing with my friends machine that needs his broken wireless card replaced.
