the 4908G-L3 is a little too much for my budget... I should specify why I desired stackable. The first installation I will be doing will be only for 4 labs and 12 classrooms (two computers per). I wish to make my proposal as futureproof as possible, hence I want to wire the entire building with fiber, fiber to every room would be the best but at least fiber for the backbone. A collapsed backbone is what I am looking for, at least presently. The reason for the singlemode is a 1700m gap between the High and Junior high buildings which must be tied together somehow, and I decided a dedicated link would be better than to tie them up via DSL (which is the internet access I am going to use - 1.5mbs SDSL). So right off the bat I have no reason for a switch that powerful as this school is probably not going to be able to pour more money into it to wire more classrooms for at least 2 years. Hence I will be idling that monster @ .5% during peak hours. That is the reason I wanted stackable - to allow for easy future expansion. If not stackable then I was looking at the 2912MF-XL (8 100BASEFX ports) to suffice until they get more money to get the rest of the rooms wired.
The main thing is the wiring for futureproofing, and what to go with All ethernet - ethernet + ATM yadda yadda. GBE is where I will be heading with the possibility of 10GBE between the buildings in 5-10 years or so.
Fiber to every desktop!? Are you sitting on a huge pile of money that you have nothing better to do with?? >>
No not really the only thing about the fiber to every desktop that gets expensive is the nics and a huge switch. Go here to see how wiring fiber to every desk can ACTUALLY SAVE YOU MONEY over the 586a structure (telecom closets / backbone). (look at next post)
What I am looking to do is get fiber to every classroom or get fiber to future telecom closets. The latter would probably be alot cheaper initially but add in the cost of the telecom closet, the equipment that goes in there and the additional wiring that has to be done from there and in the long run it doesn't seem so hot after all. I like fiber to every classroom, as it gets away with the telecom closets kinda - as you put a hub in every room, instead of hubs and switches.
So - are there any good places you guys are familiar with to get fiber? I've been to
BlackBox and
Warehouse.Com.
thx alot so far.
