I just installed an Opteron 165 and I can not get a clean POST with the two FSB settings that I have tried. I tried to first set my FSB to 266 with a 9X multiplier = 2394Mhz and I also tried 245 FSB.
On both of these setting I had HTT set to 3x, I had my RAM set to 333Mhz (should be the 5/6 divider), I disabled PEG-Link, had DDR voltage 1.75, and played with CPU voltage from 1.35-1.50 V (1.5 being highest MB will allow). With the FSB at 245 I was able to start booting Windows till it froze, and then when I restarted it told me I had a POST problem and needed to change BIOS settings (same thing I was getting with the FSB at 266). The current BIOS version I am running is 1016.
Does anyone have any suggestions? Is this a bad BIOS version? Has anyone had a similar experience with the Opteron 165 on an A8N-SLI Deluxe MB?
Thank you for any assistance or suggestion you may have.
