guskline
Well, I've finally decided to build a custom water loop. It will be installed in rig 2 below.
My case is a CM HAF 932 Adv.
My cpu is a 3930k which at present is cooled by a Thermaltake Water 2.0 Extreme.
My mb is a MSI X79 MA-45 which is the micro mb. Nice little OCer which I bought from Gillbot along with the cpu.
The gpu is a PNY GTX 680
Ram is 16gig of DDR3 -1866
HDD 1 Intel 530-180g ssd for OS (win8-64) and storage is WD Black sata3 500g.
PSU is a PC Power & Cooling MK II Silencer 950Watt.
I started this custom water cooling "adventure" by snagging a slightly used XSPC RX360 radiator for a great price.
So far I have the following
Radiator: XSPC RX360
Rad Fans: 3 Corsair SP120 High Performance fans - Scythe fan controller
Reservoir: XSPC Acrylic D5 Dual Bay Reservoir
Pump: Swiftech MCP655-B
CPU Block: Swiftech Apogee HD
GPU Block: XSPC Razor GTX680 original
Should I use another Radiator since I might want to cool the gpu at the same time
I also ordered 8 ft of 1/2"ID 3/4" OD tubing and 2 bottles of XSPC EC6 High Performance Liquid Cooling Premix Coolant - 1L - UV Blue
Suggestions???
Suggestions???
