I have 4 case fans and a CPU fan I'd like to control from the front of my case. I found This but was wondering if I should consider anything else...
Thanks,
Ed
vantec nexus. unlike sunbeams, they modulate the power to vary it. saves power when on low and low heat. sunbeam uses a normal resister. sunbeams leds are also a tad bright.
