Praxis1452
Hey, seems like my current ITX computer is probably gonna bite the dust at some point soon. It's always had issues booting up at certain points, but now it's becoming too much of a problem for me to ignore. The main problem is that I can't really figure out what's causing it although I suspect the motherboard as well as the PSU which is an issue because it's a very odd size.
Either way, I'm gonna probably grab a new motherboard and CPU at the very least, so I'm wondering what people's opinions are on the below motherboard. Seems solid, but I haven't kept up with all the hardware so I'm not sure what i5 cpu I should be choosing if that's what I really want. Currently have an e8500 OC'd to 3.8ghz.
http://www.newegg.com/Product/Produc...82E16813128448
Maybe I should consider AMD?
I think the psu has got 22A on the 12V rails as a consideration. If I finish rebuilding it and it still doesn't boot then I'd have to try and find an SFX psu with sufficient power, which may be an issue. I actually just noticed that newegg sells the exact same PSU as I have heh.
In terms of budget, I guess I'm looking more for bang for buck.
Edit: also going to need new ram. is 4gb going to be enough for the future?
