Suggestion for case
i1o0i
262
Hard to choose which case meet what I need for my future gaming pc which I will purchase in summer, so what case will you recommend me to purchase?? I thought case with motherboard tray is easy to work with, isn't it?
Away
4,430
If you are considering a case with a removable mobo tray take a look at the Antec P160.
DfiDude
627
Lian Li, Cooler Master, Thermaltake, (im not quite sure if thermaltake has slide out mobo tray).
Promethply
1,741
You may want to consider the Cooler Master Wavemaster -- it comes with removable mobo tray, a built-in option for a blowhole, and its built quality is top notch.
Zepper
18,998
You may want to look at the SkyHawk server cases on Newegg and dealsonic. Fairly heavy aluminum, mobo drawer, etc. Only about $50. and with a little modding for cooling and noise would be fine cases.
.bh.
