Suggestion for a 4870 with the best cooling?
recoiledsnake
52
Which 4870 has the best cooling and preferably pre-overclocked? I don't want to install aftermarket coolers as I am not comfortable with that.
I have a 8800GTS with a EVGA 680iLT SLI motherboard with PCIe 1.1. I mostly only play UT3 right now with a 19" monitor. Planning to upgrade to a 24" incher and want audio over hdmi so I can connect it to my Sony 46" incher 40 feet away in the living room. Forced to go to ATI because of no HDMI audio support in Nvidia's current high end cards. When are Nvidia new cards with full HDMI audio support supposed to come out?
cmdrdredd
27,052
357
The Palit Sonic Dual edition, Asus Black Knight, and the 1GB cards from Sapphire and PowerColor have the best cooling systems available. Big heatpipe with a large fan blowing down onto the GPU area.
daletkine
13
Palit Sonic Dual Edition doesn't have heatsink touching the video ram, so pre-overclocked ram has no heatsink. Sapphire 4870 Toxic which I have is pre-overclocked and has the main heatsink touching the ram chips, but it's 512MB and I don't know if the 1GB version has that. Note that the fan on Sapphire 4870 Toxic can get loud under workload, it spins at like 4000RPM under load. Under desktop use card is very quiet though and the heatsink is superb quality, highly recommend this!
http://www.newegg.com/Product/...x?Item=N82E16814102796
cmdrdredd
27,052
357
It's reviewed well here http://techgage.com/article/pa...0_sonic_dual_edition/1
Anyway, I do like the Sapphire board best. The 1GB card has the same cooling system.
F1shF4t
1,583
Originally posted by: Ares202
Originally posted by: cmdrdredd
The Palit Sonic Dual edition.
dont buy that one the fan is horribly loud
this one maybe? http://www.newegg.com/Product/...x?Item=N82E16814102801
Yep the fan on the 512mb version is loud, I think that on the 1 gig version the fan is controlled, not 100% sure though.
The stock cooler is probably the best cooler for 4870s if you do a bit of tweaking in the card's bios. Plus it also gets rid of all the heat out of the case and cools the vrms.
AdamK47
3,585
nVidia does support audio over HDMI. I've had an X-Fi connected to a GTX 280 and was able to get audio through HDMI to my Samsung LCD HDTV. All you have to do is connect SPDIF to the audio connector on the video card and then use a DVI to HDMI adapter to use an HDMI cable. It works perfectly.
