Suggest sound system for this soundcard
m3rcury
375
I just bought myself a Zoltrix Nightingale Pro6 soundcard that does 6 channel sound. I would like a good speaker system to go with it. My budget is around $150. Should I just get regular 4.1 speakers for the computer, or should I buy a CD Player (Sony or AIWA or the sort) and hook that up to the computer? With the CD Player, I get the added functionality of tape player, radio, remote, probably a multi cd changer and all. With computer speakers I just get ... well ... speakers for the computer. So If anyone has such a setup, with a CD Player hooked up to your computer, or if you know much about them, please recommend a good CD Player that I can hook up to a 6 channel soundcard. I would be more than happy with a 4 speaker CD Player, so if i get a 5/6 channel one, i'll be very satisfied. Thanks.
