suggest laptop under 55 k for 3ds max
khuranarajat
suggest laptop under 55,000 rs
Mainstream; 15" - 16" screen
i will be taking this laptop for animation,designing and some gaming also
should last at least 3 years.
and which brands after sale service is good in india?
have seen
dell studio
xps 15 with i5 processor and 420 m graphics card
asus n61jv
Intel® Core™ i5 Processor 450M(2.4G, 3M) : GHz
Main Memory 4 GB DDR3 1066
Display 16" HD (1366x768) 7” WVGA (touch panel/sun readable)
Video Graphics & Memory NV GT325M 1GB DDR3 VRAM
lenovo
Core™ i5-460M
4G DDR3 1066MHz
1GB Graphics ATI Mobility Radeon HD 5730 / 15.6 HD LED
Acer Aspire 5745G
Intel Core i5-430M 2.26-GHz processor
4GB DDR3
Nvidia GeForce GT 330M (1GB)
any of them is good or not?
thanks
Well, you'll want the one that gives you the most powerful cpu and most ram for the 3DS Max and since gaming is also on your list you are going to want the one with the best GPU as well. Based on your choices given I'd say the Lenovo but I'm not sure that 5730 will be good enough. I cant recommend anything better because I dont know what the conversion rate into US Dollars is. Just remember, you want most powerful CPU and most RAM you can buy because they will directly effect how well you can run and render animation more than anything else. I'd say you'd want a 1GB GPU type of card.
3DS Max System Requirements:
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=13571366
thanks for replying it has helped me .....my budget is around $1000...and in inr 55k....
