Suggest a nice 2.1 system for my PC
DarkTXKnight
933
I have an old logitech z5300 5.1 that's starting to have issues and I think Id like to go to a new 2.1 system. I mostly want to listen to music and movies with some medium gaming. Can anyone suggest something in the ~ 100 to 150.00 range? Right now the audio is coming through an MSI-870A G54 MB. If anyone has an opinion on whether to add a sounds card or not Id appreciate it too.
DarkTXKnight
933
i didnt think of those - i have am 8 year old promedia system that i used to use before something started going wrong with the connectors. are they still as good as they used to be?
fralexandr
2,289
229
www.flickr.com
the klipsch promedia 2.1 are still a good set.
i think newer sets are supposed to have fixed some of the issues causing aged klipsch promedias to fail
the swan m10 are also good. You lose out on a lot of the bass the klipsch puts out, but get noticeably cleaner/clearer sounding audio. For gaming and movies, explosions and other low frequency audio don't sound as impressive/loud though. Also, blue LEDs are annoying, I have to cover the volume adjust knob to sleep at night, heh :p.
http://www.theaudioinsider.com/prod...top-loudspeaker-system,-white&products_id=89&
apparently (if you don't like the white face) they also have a black set now, but there isn't a picture for it
they also have a refurb with full warranty for $100 + shipping (shipping is ~$20)
you might want to look into getting a 2.0 set like the m-audio AV-40
http://www.bhphotovideo.com/bnh/cont...=REG&A=details
Childs
11,313
7
I never had the 2.1 set, but I did have the 2.0 and I liked them.
Do you really need 2.1? M-Audio has those AV40s which people seem to like.
DarkTXKnight
933
well i had never thought of NOT having a subwoofer... would a 2.0 system deliver the same level of bass?
fralexandr
2,289
229
www.flickr.com
you're not going to get as much bass out of the M-Audio AV40s as you would from the klipsch.
If you want comparable bass, but better sound quality you'd have to go with either the M-Audio BX5 (~$200) or go with a passive speaker + speaker cable + amp and some way to connect the amp to PC (usually 3.5mm to 3.5mm, but can be edit: RCA to 3.5mm)
you can get much better sound quality for the price with an amp + speakers, but it'll take up more space
something like this is often recommended
amp ~$20
http://www.amazon.com/LP-2020A-Lepai...rds=stereo+amp
speakers ~$50 (the pioneers may be weak on the bass though)
http://www.newegg.com/Product/Produc...bles-_-na-_-na
maybe you can find some infinity primus near you (you'd need to buy 2 as it's $50 each)
http://slickdeals.net/f/4937978-Infinity-P153BK-bookshelf-speaker-49-99-Frys-B-M
speaker cable ~$13 (including shipping)
http://www.monoprice.com/products/p...=10239&cs_id=1023903&p_id=2822&seq=1&format=2
3.5mm male to 3.5mm male cable ~$4 (combined shipping from speaker cable)
http://www.monoprice.com/products/p...=10244&cs_id=1024407&p_id=5496&seq=1&format=2
richaron
1,357
329
I would also go bookshelf speakers & amp but that's just me. Having more components gets a bit messy tho, & takes up more space.
For something easy/compact(/prebuilt) @ $100 I would seriously consider the creative gigaworks T40's. For ~$150, like people said, the M-Audio AV40s are awesome. As above; these are both lacking in sub-bass, but still very nice (easily enough bass for normal music & gaming).
I wouldn't bother with a sound card...
