Suggest a celery recipe for me
Terzo
2,589
27
I have some celery and I after some quick searching the only recipe I've found that sounds simple and appetizing is a onion celery mix.
What do you suggest for a quick and tasty celery dish? I'm fine with mixing the celery with another vegetable or some chicken, but I want it as more of a main course/side dish rather than appetizer; that means no celery + peanut butter or hummus.
Ideally cooking plus prep time should total no more than half an hour.
sandorski
70,784
6,343
Celery Dish? No such thing. Peanut butter, cheese whiz or similar spreadable cheese, in a sour cream dip, or added to a stew/sauce. Take your pick.
33,951
First place different stalks in an assortment of glasses containing food coloring in water. Be sure to trim the ends of the celery to expose a fresh edge to the water. Celery should take on the colors. Now spread peanut butter on your fiesta celery and eat.
sandorski
70,784
6,343
Fine...
First place different stalks in an assortment of glasses containing food coloring in listerine. Be sure to trim the ends of the celery to expose a fresh edge to the listerine. Celery should take on the colors. Now spread peanut butter on your fiesta celery and eat.
Tasty peanut butter and fresh breath! What could possibly be the downside to that?
preCRT
2,340
123
Cheapo Asian restaurants use lots of celery to stretch out Kung Pao recipes. Actually they use it instead of more expensive veggies like broccoli, pea pods, water chestnuts, red peppers, baby corn, pea shoots, mushrooms, etc. in lots of dishes.
Celery is just cheap, nutrient poor crunch. Just chop it up and throw it into any other dish.
ABitTooSpicy
922
Celery is actually quite good with Tuna.
You grind up the Celery and Onions if you like em, mix with Tuna (out of a can is fine) mix it all up with a little lite mayo (taste the same as regular mayo and about half as bad for you). Put that on some good bread, throw a slice of cheese on it, throw it in a toster oven or regular oven and you got yourself an excellent tuna melt!!
Iron Woode
31,298
12,818
celery is high in calcium and fiber.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
My favorite celery dish of all time is braised celery hearts with bernaise. PSA Don't ever try to serve it in the SW because no one knows what it is.
guyver01
22,135
61
Thin Sliced Wayu beef...
run some celery thru a mandolin..
Beef Carpaccio
lykaon78
1,174
9
Bobboli Pizza Crust
1/2 Cup Buffalo Wing Sauce (I prefer Frank's or Sweet Baby Rays)
Mozzarella
Diced pre-cooked chicken (You can usually find the perfect amount pre-cooked and diced near the deli section of your grocerer)
Red Onion
Celery
1. Toss chicken in sauce place on pizza
2. Cover in Mozzarella
3. Add Onion and Celery to your preference
4. Bake according to the instructions on the pizza crust.
5. <Optional> After baking lightly squeeze ranch or blue cheese dressing on the pizza in streaks.
