sudden reboots after 1 month rock-solid
Qythyx
87
I have a Soltek SL-75DRV5 and recently started having some problems. The problem is that my computer will suddenly reboot. I bought my MB about 1 month ago and it was running fine until 2 days ago. During this time the computer was turned on 24 hours every day. Then, 2 days ago, it started rebooting spontaneously. It would reboot, run for 5 or 10 minutes, and then reboot again, continuously.
MotherBoard Monitor reports all of the voltages as normal and the CPU temperature as between 48 and 51 degrees C. So, I think that temperature is not a problem. I also checked the BIOS temperature setting and it said the same thing, about 48 degrees. BTW, my CPU is an Athlon XP +1800.
I also checked the BIOS setting for automatic temperature shutdown but it was set to 70 degrees so I don?ft think this is the problem because it is only 50 degrees or so. I even tried turning off this BIOS setting but the problem still occurred.
Usually when my computer runs I'm running Prime95 (which really uses the CPU a lot). When I run with this program running my temperature is around 51 degrees. If I turn off this program so that my CPU is only 0% or 1% used then the temperature goes down to around 48 degrees. BUT, I think that 48 degrees is quite hot for the CPU when it is not used.
I also noticed that if I run my computer with Prime95 not running then my problem is OK and the computer does not reboot. BUT, this is very strange because I ran Prime95 for 1 month with no problems. Why is it now suddenly a problem?
Also, I will admit that the weather's been a little warmer here but only a few degrees. It's not like it's the middle of summer. The room temperature is still around 25 degrees C if not cooler. As for my case I have 2 intake and 2 outtake (including the power supply) fans. I'm pretty sure there is enough ventilation. Again I point to the fact that it was running fine for 1 month.
Any ideas????
Duvie
16,215
answered it in the other forum....
I don't think the mods appreciate multiple same topics in diferent forums...I could be wrong but I think I remember they frown upon it....FYI
Qythyx
87
Oops, sorry, I didn't realize that. I was just looking to get wide coverage. Is there any way for me to close or delete this thread, then?
Woody419
770
Everyone here knows that 30 days is the limit for a trouble free computer, time for an upgrade.
The problem could be as simple as a bug in the Prime 95 program that is conflicting with a recent program or update you installed. Don't use Prime 95 anymore and live happily ever after.
There are stress test programs that will stress and log failures if you want to check if your ram or cpu is going bad.
Burn in Test
CPU Load and CPU Stability Test
Hot CPU Tester
Doc Memory Ram Tester
