Sudden problems w/usb adaptor...please help!
Tullphan
3,507
I have the Microsoft wireless home networking kit (MN-610). Everything has been working fine up until this morning when the kid said she couldn't connect to the internet (on the secondary pc). I looked & it had a yellow exclamation point where the wireless adaptor icon usually is. It said "limited or no connectivity". I've tried repairing, re-installing the network & doing the "renew" thing to no avail. Is it possible the usb adaptor's gone bad? Both lights are on, meaning it's connected, but on the MS Broadband network utility, it doesn't show any network devices except mine (which is working fine).
Ideas? Suggestions? Any help would be appreciated!
beyoku
1,568
i ahve no idea? Sorry i am of no help - BUT depending on how long ago you bought it you may want to call he tech support from the company if its free - or search the web incase it has been a manufacture defect, - you may be surprised at what you find.
Kelemvor
16,928
8
I'd try power cycling your router first. Might have lost a good connection out. THen have it try to connect again.
Also go to Device Manager and uninstall the USB thing and then pop it back in so it can reinstall itself.
