My main box has suddenly started shutting down for no reason that I can determine. I'll be doing something normal, or even be away from the box, and it will just power down. The power light remains lit, however it sounds exactly the same as if the machine were turned off via the power button. I will then have to turn off the switch on the power supply itself off for 20 sec or so, and I can then power the box back up.
I suspect the power supply, a 430w, is starting to get flakey There have been no changes for several weeks, and it just started to occur today. It's not a temp issue, there have been no changes on that front. Anyone else seen anything like this, or have any ideas? Here's the specs:
430w ps
8RDA+ @ 11.5x200fsb, stock voltage
3000+ retail
SLK-700 w/74mm TMD fan
GF5 Ti 4600 w/blue orb hsf
DVD
CD-RW
120gig Maxtor hdd
1 thermaltake 80mm smartfan II case fan
2 60mm aluminum case fans, one 25mm think, one 10mm thick
Vantec CCB-A1C hsf on northbridge.
430w ps
3000+ retail
DVD
CD-RW
120gig Maxtor hdd
