I've just recently reseated my Zalman CNPS7700, having removed it to clean up the wiring.
I covered all procedures, cleaning the CPU cap and heatsink base thoroughly using
rubbing alcohol and a lint-free cloth. Reapplied Arctic Silver 5, placed the heatsink
back on VERY carefully and tightened the screws enough so that the heatsink won't budge
when tapped or when the case is moved.
Here's the problem:
Before, my CPU was running at 42C idle and 51C load
Now, it's running ~48C idle and godknows how much load (too afraid to test)
Everything was done the way I've always done it, this is the first time
that I've encountered a spike like this. What could've gone wrong?
EDIT: There are some tiny holes on the HS's plate, they look like holes a termite would
make through wood (that can't be good)
Here's the problem:
