Suck or Blow - fan on CPU heatsink
BCinSC
2,084
I'm sure it's been asked before, but which is better? I have some of each.
nitromullet
9,031
36
I think it really depends on the design of the heatsink. They are usually designed for either one or the other, and I don't think that it has ever been established that one design concept is better than the other.
HokieESM
798
Depends on the heatsink. Follow the manufacturer's recommendation. The Swiftechs are almost always "suck" heatsinks (particularly the kinds with "pins")... but I think all Thermalrights are blow. (man, this topic is going to degrade in a hurry because of the terminology).
nick1985
27,153
would you rather have a fan blow on you when your sweaty, or stand behind the fan and have it suck the hot air off you...
John
Moderator Emeritus<br>Elite Member
4
That is correct. Alpha's also like to suck air.
WobbleWobble
4,867
That's different... kinda. In a case of a hot person, there's moisture involved. CPUs don't sweat :)
But I'd blow... wait, that doesn't sound right :p
John
4
Unless you have a hot peltier. ;)
batmanuel
2,144
My Aero 7 Lite is all blow, all the time. And with a turn of the knob, I can make it blow as hard as I want when things get really hot.
JustAnAverageGuy
9,057
I would assume suck to get the hot air out of there ASAP while cooler air moves into replace the now sucked out air.
