Such thing as a high revving V8 crate engine?
Eli
Super Moderator | Elite Member
8
Or would it have to be custom built?
"high revving" = 8000RPM or more.
Jan 31, 2006
167
I've heard of people making a 383 stroker and using the left over small block 400 and 350 crankshaft in roundy round high rev cars. I think I have that right, 350 block + 400 crank = high torque, 400 block + 350 crank = high rpm. Do some looking around on that, I bet there's more too it than just a crank shaft swap, but that's the just of it.
I don't know if that would translate to 8k rpm either.
Iron Woode
31,298
12,818
why do you want to rev your v8 that high for?
what is the application?
you could get a really big bigblock and then there is no need to rev the hell out of it.
building a v8 to run 8000+ rpm is a tough job. The forces at work on the reciprocating assembly are astounding.
Howard
47,982
11
I'll bet Eli fancies himself with the same engineering expertise as an F1 team. ;)
olds
50,124
779
I have friends who race that go that high. Not sure if any/many street engines do.
Sqube
3,078
The real question is why you feel the need/desire to get your V8 revving to 8000 RPM. I mean... it's a V8. That's pretty beefy as is.
Kadarin
44,296
16
Indeed. You have to worry about things like the quality of the rods and rod bolts, the weight of the pistons and flywheel, windage trays, and whatnot. This is not to mention selecting the proper components in order to be able to actually make horsepower at those rpms (cam grinds, cylinder head design, intake/exhaust, and so forth).
No, you're not likely to find crate engines that will do this.
boggsie
2,326
I would imagine that GM Performance Parts has something available as a crate that would go as high as 6800 rpm, which is pretty darned good for $7000 with a 3/36 warranty.
Other than that, you would have to look for something from Lingenfelter or another builder shop that did a standard build, but look to pay upwards of $15,000.
If I might ask, why 8 grand RPM?
olds
50,124
779
Agreed. Not many if any crate motors come with the titanium valve parts or fuel supply needed to spin that high. (And as you mentioned, cam grinds)
compuwiz1
Admin Emeritus Elite Member
930
You can buy any hot crate engine you want, but your cam is going to limit you. Also, I would not rev a non balanced and blue printed engine that high.
Take a look at the 572 Chev Crate engine, with 600 HP. :)
Black88GTA
3,430
Got $14,575?
Not quite 8k RPM, but...
930HP @7200 RPM :Q
760 ft-lbs @ 5500 RPM
555 cubic inches
Or, this 1160 HP monster
1160 HP @ 7000 RPM
950 ft-lbs @ 6000 RPM
632 C I
$21,995 :Q:Q
1700+HP with NOS Dual Pro Fogger as shown, not included.
Mother of God.
boggsie
2,326
GMPP 12498826 ZZ572/720R Base Crate Engine
Max RPM 6750
GMPP 12499468 Northstar 4.6L V8 Production Engine
Max RPM 6700
GMPP 12568722 LS1 Production Engine
Max RPM 6200
cavemanmoron
13,664
28
define "crate"
define what brand, engine, and useage.
For the street a V8 usually only sees about 5,000 rpm max.
Heck my car at 100 mph is only turning about 4,000 rpm.
Eli
8
LOL, I'm well aware of how difficult it is guys. ;) It's certainly not impossible though.
Why 8k?... Because it would be unique, and it woud sound badass.
Chevy? 350? Usage?.... In my truck? Or maybe a 240Z?
Maybe I should have said "turn-key" instead of crate. Are there any engine builders that offer them for sale?
Iron Woode
31,298
12,818
:roll:
lots of serious drag race engines rev like that. They are not streetable.
for the street I would shoot for 6000 - 6500 rpm max.
I will tell you that my 5500 rpm 318 sounds pretty damn sweet.
Eli
8
:roll:
Why the roll? Is it wrong to enjoy the sound of an engine?
What do you mean "not streetable"? As in too much power? lol....
Iron Woode
31,298
12,818
:roll:
no, as in way too peaky a power band, too steep gears, serious overheating issues in traffic, lousy mileage (yeah, I know), parts that can and will break when you least espect them to, too loud (yeah, I know) and just too expensive.
