So I got my system assembled and running last night without any real problems (A64 3000, ASRock K8S8X, AIW 9600XT). The only thing was that I had to manually create a SATA driver disk, since for some reason I couldn't boot all the way from the Support CD. After that, everything was flawless. No crashes or errors of anykind. I see why everyone seems to like this board. . . Couple of questions though:
1. When set to 'Auto' the system detects my RAM as DDR333. I manually set it to DDR400 and it runs fine, just curious as to why this would happen. It's a 512MB stick of PC3200 from Crucial.
2. Although my idle temps seemed reasonable (45C), I'm up to 56C (According to SpeedFan, is there something better?) after running Prime 95 for about 8 hours (no errors). Is this ok? I've heard temps will come down some after an initial "burn in", is this correct?
