Subwoofer Vibration
Exterous
20,553
3,713
With our new setup, my subwoofer is on top of a cabinet and vibrates the hell out of it. Unfortunately I had to make the deal that it would go where ever my wife said it would in order to not die after buying it
So - how do I reduce the vibration transisiton between the sub and the cabinet. Would some rubber disks work?
spidey07
65,469
Upgrade the wife?
Try spikes. The cabinet is basically a speaker so try to not put the cabinet vibrations into this large "speaker".
If it HAS to go there, you could build a shelf from the wall to decouple the sub from the cabinet.
montypythizzle
3,698
Towel?!?
I actually have rubber dampeners on my sub bottom because of our wood floors and sometimes the floor and subwoofer bottom does not match up and it vibrates.
emfiend
100
If its the contact vibration thats bothersome (rattling between two surfaces in contact), probably some soft feltpaper would do the trick.
If the cabinet vibration is caused by the acoustic waves travelling through it, then isn't that what a subwoofer is supposed to do?
Tiamat
14,068
If it is mechanical vibration caused by contact, try an auralex subdude. If it is vibrating due to the resonant frequency of the cabinet getting excited, you are out of luck. You would have to mass dampen the cabinet which may or may not be possible.
Exterous
20,553
3,713
Thanks for the suggestions guys! The cabinet is vibrating due to the contact with the sub, not the sound waves so I will try some of those solutions out
Tiamat
14,068
Cheapest method is a bunch of scrap bath towels underneath the subwoofer. If you notice it starting to help, but dont want to spend 50$ on auralex subdude, a sandwich of towels, woodplanks, styrofoam, may get the job done.
herm0016
8,500
1,116
i have bubble wrap under my TT and preamp. it seems to work well to get rid of the vibration in my rack from the computer HD and fans. maybe try that?
biggestmuff
8,201
Hockey pucks.
The real solution would be to move the sub to a location in the room where it sounds best at your viewing position. Put your foot down.
destrekor
28,799
359
Originally posted by: biggestmuff
Hockey pucks.
that, or turn the sub volume up so that you no longer hear the vibration. :D
Exterous
20,553
3,713
Hockey pucks.
I wasn't paying attention to my wife's obsessive decorating and she put a glass candle holder on top of the cabinet. It vibrated right off of it and shattered on the floor.
Actually here is a pic of the setup now:
http://img148.imageshack.us/img148/2793/img3801dv9.jpg
I don't have this problem with the Infinity PS8 that the sony is replacing temporarily (down for repairs) just the sony. Towels are a no no (call me whipped but she lets me spend lots of $ on electronics and put the mini-fridge between the couch and loveseat as a beer fridge :) )
I'll try the rubber mouse pads (upside down of course) and maybe move on to the rubber dampeners
Tiamat
14,068
Originally posted by: montypythizzle
LOL, that Sony is vibrating?!?!?!
better subwoofers are more inert, so I think it makes sense. While my subwoofer is pumping 100dB at 20-30hz, the exterior is perfectly still. The driver is undergoing excursion, but the cabinet is inert. The only troublesome thing I have is when the natural resonance gets excited in my floor (23hz).
Oyeve
22,043
875
Im sure its a plastic cabinet. That would vibrate like mad, powerful or not. My JBL Sub250 is solid wood on metal spike, while I can feel the bass on my chest, nothing vibrates when it is on top of the sub. I even put a glass of water on it and it barely rippled even at pounding levels.
montypythizzle
3,698
Yeah, I need to get some spikes, these little rubber pads aren't helping, I think they are too hard, I think they are just so stuff doesn't slide, not really vibration dampening.
PurdueRy
13,837
4
No, in fact it is wood. It's just built with .5" thick particle board instead of the more accepted 3/4" or 1" MDF.
cheesehead
10,079
Brace the box, and you'll have a better sounding sub, too.
Step 1: Remove subwoofer driver.
Step 2: Glue in three dowel rods: One from top to bottom of box, one from side to side, and one from the back to the back plate of the woofer.
Step 3: Put some pillow fluff inside the box. They usually do this all wrong at the factory.
You can also kill vibration by putting a small square of carpet under the sub.
